learn parameter
learn parameter
When I was doing Learn Parameters... from Data, and tried to drag and drop the network to match data, the "drag and drop" is not working, i.e. they can't be draged and dropped to the Matching column. Could someone help?
Thanks.
Thanks.
Re: learn parameter
Can you upload your data and network? I'll be able to check what exactly is the problem.
it worked!!
Now since the issue is similar (drag and drop) for creating DBN. It is not clear how the Rain_1 box is created in the tutorial (or help manule) for Create DBN. drag-and-drop does not pop up that box automatically. The procedure is in the help manual, and I tried to follow the process there.
To create the circular temporal arc, enable the arc tool in the GeNIe's toolbar, then start dragging from Rain node, move the mouse pointer out of Rain, then move it back into Rain and release the button. You should see the popup menu with 'Order X' items - select the right temporal order and you should see new temporal arc.e078449 wrote:it's in the GeNIe help manule, if you search for Creating DBN.
I can go up to Step 2, and don't know how to start and complete Step 3, where the nodes are created and linked as shown. (like Rain module [1] and temporal links).
