reading .csv extension file while learning
masterblaster
Does jsmile api support .csv file while learing structure from dataset. The front end engine genie reads .csv file but does jsmile support this file extension? Is there any way to learn from .csv file from jsmile api?
Re: reading .csv extension file while learning
The internal SMILE parser (which jSMILE exposes through DataSet.readFile) supports tabs, commas and spaces as possible separator characters, so your .csv file should load fine.masterblaster wrote:Does jsmile api support .csv file while learing structure from dataset. The front end engine genie reads .csv file but does jsmile support this file extension? Is there any way to learn from .csv file from jsmile api?
