Trying to compile sample code from the wiki generates linker errors
BNSimplifier.cpp: In function ‘void PrintDataset(const DSL_dataset&)’:
BNSimplifier.cpp:15: error: ‘const class DSL_dataset’ has no member named ‘NumVariables’
BNSimplifier.cpp:16: error: ‘const class DSL_dataset’ has no member named ‘NumVariables’
BNSimplifier.cpp:52: error: ‘const class DSL_dataset’ has no member named ‘At’
BNSimplifier.cpp:54: error: ‘const class DSL_dataset’ has no member named ‘At’
among others ...
I have inspected libsmilearn with nm and I see no sign of these methods in there. Is there something wrong with the library? Perhaps it is an older version. I would appreciate any help.
Thanks.
Cannot compile sample code with smilearn linux64_gcc_4_1_2
Re: Cannot compile sample code with smilearn linux64_gcc_4_1
Unfortunately, the code in the documentation is outdated. Use DSL_dataset::GetNumberOfVariables instead of NumVariables. The DSL_dataset::At was replaced by GetInt and GetFloat.
