i'm new in jsmile. I want to set this property to my node properties.Can you please help me?
I report the code here.
UserProperty[] properties = tNet.getNodeUserProperties("cost");
UserProperty newProperty = new UserProperty("DSL_NOLEARN", "ALL");
List<UserProperty> props = new ArrayList<UserProperty>();
for (int i = 0; i < properties.length; i++) {
UserProperty userProperty = properties;
props.add(userProperty);
props.add(newProperty);
properties = (UserProperty[]) props.toArray();
tNet.setUserProperties(properties);
Is it correct?
Set [DSL_NOLEARN = ALL] userproperty in JSMILE?
peppe.chiapparo
Re: Set [DSL_NOLEARN = ALL] userproperty in JSMILE?
It'll work, but you may want to use one of the following methods in smile.learning.EM class:peppe.chiapparo wrote:Is it correct?
public void learn(DataSet data, Network net, DataMatch[] matching, int[] fixedNodes);
public void learn(DataSet data, Network net, DataMatch[] matching, String[] fixedNodes);
