DataSet.AddRecord(rec) not available in DotNet Build?
Christian
Post by Christian »
I am just messing with the DotNet Smile wrapper build, but I found no possibility to add records to a dataset beside using ReadFile.
Is there really no way? I think writing a Textfile and reading it again is not so good. Maybe there is a way and I haven't found it.
In C++ there is a AddRecord method, is this one not available in the dotnet/java build?
Thank you and happy Christmas,
Christian
Re: DataSet.AddRecord(rec) not available in DotNet Build?
jSMILE/Smile.NET have AddEmptyRecord method, which does exactly what the name implies :) You can set the values with freshly added record with SetInt or SetFloat.
