The smilehelp.chm published inside the .zip has few small defects.
1. No constructors are documented. Surely SMILE clients will call the constructors, and they take parameters. Do they not need documentation?
2. The file claims that in order to use the XDSL format, one needs a separate library. This is no longer true.
3. The tutorial 2 code is wrong - though the tutorial 2 appendix code is right.
Thanks for publishing SMILE, even in binary-only form.
Small defects in smilehelp
Re: Small defects in smilehelp
The .chm file is no longer updated; the docs have been moved to the Wiki at http://genie.sis.pitt.edu/wikiJohnicholas wrote:The smilehelp.chm published inside the .zip has few small defects.
