GetOutcomeIds(handle) does not work for value node
sez
Post by sez »
The following code is working for chance node but not working for Value Node
error:
foreach (int handle in net)
String[] outcomeIds = net.GetOutcomeIds(handle);
Could you tell me why or is there other method I can use?
error message
error message
Re: GetOutcomeIds(handle) does not work for value node
That's by design - the value nodes don't have outcomes. What are you trying to do?
sez
value node
Post by sez »
We have several Chance nodes and Value nodes.
We need to get the value of Value Node
sez
Post by sez »
Also, we need to read BN file and get all of those nodes(Chance, Value),
how to identify or distinguish change node and value before the method of
GetOutcomeIds?
If it is Chance node then
use GetOutcomeIds
else
use other method
Try Network.GetNodeType method and Network.NodeType enum.
sez
Post by sez »
we have a couple of chance nodes and few value nodes.
What is the best way to get Value Node value
double expectedUtility = net.GetNodeValue("Node1");
sez wrote:What is the best way to get Value Node value
double[] expectedUtility = net.GetNodeValue("Node1");
sez
Post by sez »
One more thing.
I guess getting the value of MAU Node is as the same as the way get Value Node mentioned above?
sez wrote:I guess getting the value of MAU Node is as the same as the way get Value Node mentioned above?
Yes.
