Discretizer & Missing values
kile
Post by kile »
Hi all, yes it's me again hehehe :)
I'm trying to read a data file and automatically discretize the parameters that are continuous, I've been reading the tutorial about discretization but it gaves the following code:
  DSL_discretizer disc(d.GetVariableData(0));
  disc.Discretize(3,DSL_discretizer::MethodType::Hierarch);
But now the method GetVariableData it's not available anymore. Which one should I use if I dont know before reading the kind of data that is coming?
I was thinking in something like the next:
for (int i=0;i<m_dataSet->GetNumberOfVariables();i++)
    if (!m_dataSet->GetVariableInfo(i).discrete)
        DSL_discretizer disc(m_dataSet->GetVariableData(i));
        disc.Discretize(8);
I dont know if I get wrong way how it's work.
Another question is regarding how I could include also automatic missing values replacement like in Genie -> Replace using average value. Is there any built functionality to make it? or it should be made by hand?
Thank u very much as usual
Re: Discretizer & Missing values
kile wrote:But now the method GetVariableData it's not available anymore. Which one should I use if I dont know before reading the kind of data that is coming?
GetVariableData was replaced by GetIntData/GetFloatData. To check the type of the dataset column use IsDiscrete method.
This functionality is implemented in GeNIe, so you'd have to write it yourself. Note that vectors returned from Get[Int|Float]Data are const, so you'll need to make a copy before filling in missing values and passing it on to discretizer.
