K-Fold Crossvalidation
kile
Post by kile »
Hi all,
I was looking thorugh the forum and i found it http://genie.sis.pitt.edu/forum/viewtop ... ight=cross
I assume any changes since that post so I started to create my own crossvalidation function. The problem is that I was thinking to do something like the following:
DSL_dataset m_dataset;
m_dataset.ReadFile(filename);
DSL_dataset learnDataset=m_dataset;
DSL_dataset trainDataset=m_dataset;
for indices in train
     learnDataset->RemoveRecord(indice)
for indices not in train
     trainDataset->RemoveRecord(indice)
But first of all, I was thinking it has overloaded the = operator so it will not be a pointer to the same data, but it's not so after deleting from each dataset it's deleting from the others :(
And secondly as I'm removing records while indexing next ones, those indices are not valid anymore.
The only solution I can imagine is to export both data to text files, and then read each one on each dataset but it's sound not very nice :(
Any help?
Re: K-Fold Crossvalidation
kile wrote:But first of all, I was thinking it has overloaded the = operator so it will not be a pointer to the same data, but it's not so after deleting from each dataset it's deleting from the others :(
Thanks for reporting that issue. Technically what's missing is the copy constructor; the default one using memberwise copy (generated by the compiler) is not adequate. Please add the code below in the definition of DSL_dataset class in dataset.h:
DSL_dataset() {}
DSL_dataset(const DSL_dataset &src) : metadata(src.metadata)
	int varCount = src.GetNumberOfVariables();
	data.resize(varCount);
	for (int var = 0; var < varCount; var ++)
		if (src.IsDiscrete(var))
			data[var] = new std::vector<int>(src.GetIntData(var));
		else
			data[var] = new std::vector<float>(src.GetFloatData(var));
You can easily fix this by removing records in the loop proceeding from the last record towards the beginning of the data. Alternatively, you can use forward-going loop and increase the index only if record was not actually deleted.
kile
Post by kile »
Thank u very much schooltz, I added it and copyFrom(...) to have a copy function not just in the contructor.
The loop I think I've managed too ^_^
I'll post my version of K-fold when i'll get it working i think will be useful for someone.
