Hello, I am just trying the API, but have problems to figure out the exact name of the algorithm in relation to the used constants.
I looked in the C# and C++ help
I think I figured out that DSL_ALG_BN_LAURITZEN is the clustering algorithm.
Is DSL_ALG_BN_LSAMPLING the logic sampling or the likelihood sampling algorithm?
As the likelihood algorithm seems to be very fast (3.2ms for a 20 million cpt network), but the results are not that good, can I just call updateBeliefs about 20 times and use the averages? Or is that something that will not help that much?
Which algorithm are you using normally for such big networks if you want the best relation between speed and accuracy?
Thank you very much,
Christian
DSL_ALG_BN_LAURITZEN and DSL_ALG_BN_LSAMPLING
Re: DSL_ALG_BN_LAURITZEN and DSL_ALG_BN_LSAMPLING
Increase the number of samples with DSL_network::SetNumberOfSamples. The default is 1000, which is certainly too low for huge CPT you have.
You may also try DSL_ALG_BN_EPISSAMPLING.
