Bug? using MAU /ALU nodes and equation nodes
joergweber79
Post by joergweber79 »
using MAU or ALU nodes in the same submodel like an equation node cannot be computed. in the output window the message occurs:
"Unable to handle hybrid networks with equation solver."
Should genie behave that way?
In my network i have several MAUs if i place a single not connected equation node, the application crashes.
Can anyone help? Solve the problem?
Thanks in advance,
Joerg
joergweber79
The following file causes a crash
Hello dev-team,
i have a file now, in which the bug can be reproduced. Simply click until you are in subnet "3" and hit "run".
It would be kind if you'd fix it.
Greetz
Joerg
XXXXXTest_equation node.xdsl
Buggy file
(9.64 KiB) Downloaded 1171 times
Re: The following file causes a crash
joergweber79 wrote:i have a file now, in which the bug can be reproduced. Simply click until you are in subnet "3" and hit "run".
Thanks for finding the problem. Submodels have nothing to do with it, so you can just as well place all nodes on the main level. The continous nodes is still an experimental feature and we do not support a mixture of continuous and discrete nodes fully. Stay tuned (quite likely some time in March).
