Hello
I am new to smile and am trying to compile a very basic peice of code as a start. I am running Gentoo Linux on 64bit machine, using gcc version 4.3.1. I have downloaded smile_1_1_linux64_gcc_4_1_2.tar.gz and am using those header files in a sub directory. When I try and compile my code I get an undefined reference error:
main.cpp:(.text+0x7b): undefined reference to`DSL_dataset::DSL_dataset()'
Makefile
SMILE = /home/me/Desktop/Smile\ trial/Smile_Headers
CFLAGS=-I/usr/X11R6/include -DEDEBUG -ffast-math
LDFLAGS=-L/usr/X11R6/lib
pc: main.o
g++ -g $(LDFLAGS) $(SMILE)/libsmilearn.a -o pc main.o
main.o: main.cpp
g++ $(CFLAGS) -c main.cpp -w
main.cpp
#include <iostream>
#include "Smile_Headers/smilearn.h"
using namespace std;
int main (int argc, char *argv[]){
DSL_variableInfo vi;
DSL_dataset ds;
Please could you help me with this problem.
Thanks.
Undefined reference problem when compiling smile
Re: Undefined reference problem when compiling smile
You have a space in $(SMILE) - it's between 'Smile\' and 'trial'.
Thanks for the reply, though I am still stuck with the error. I have replaced the space with an underscore now:
SMILE = /home/me/Desktop/Smile_trial/Smile_Headers
However I still get the same error. I also tried commenting out the "DSL_dataset ds;" after which the code then compiled correctly. I don't know if there was a form of instillation (./configure?) that I maybe missed.
There's no install/setup - unpacking the files is enough.mepster wrote:However I still get the same error. I also tried commenting out the "DSL_dataset ds;" after which the code then compiled correctly. I don't know if there was a form of instillation (./configure?) that I maybe missed.
What happens if you invoke gcc directly, like this? xxx is the location of libsmilearn.a and libsmile.a.
g++ main.cpp -Lxxx -lsmilearn -lsmile
That worked. Thanks. It turns out the main.o was at the end of the line when it actually should have been at the begining. So my final makefile is:
CFLAGS= -I/usr/X11R6/include -DEDEBUG -ffast-math
LDFLAGS= -L$(SMILE) -lsmilearn -lsmile
pc: main.o
g++ main.o $(LDFLAGS) -o pc
main.o: main.cpp
Thanks for the help.
pc: main.o
main.o: main.cpp
