This is a dumb question but I just want to confirm...
I want to learn a new network (both structure and parameters) from data. If I use GTT (https://dslpitt.org/genie/wiki/JSMILE_L ... ckThinning), is the returned network the complete learned network with both structure and parameters already learned? Or is the network just contains the structure with some default parameters and I have the use another pass over the same training dataset with a different algorithm to learn the parameters? I think it is the former, but please clarify.
jSmile Network Learning
Re: jSmile Network Learning
GTT will run parameter learning (and so will other structure learning algorithms).
For structure learning we currently recommend Bayesian Search.
