Hello!
I'm using GeNIe 2.0 to learn a Bayesian network. I can't open database and text files. Message is "Unable open database file". Could you tell me why this problem occurs?
Can't open database files
Re: Can't open database files
I can't diagnose the problem without more information. Can you post your text file here? Can you open the data files from the 'examples' directory (located in GeNIe's install dir).alesya wrote:Hello!
My actions are as following:
I open File -> Import ODBC Data...
Then in dialog window that appears I choose "MS Access 97 Database (not sharable)". In the next window I choose retention.mdb (this file is located in GeNIe 2.0/Examples/Learning and as I understand is a standard one and deployed with GeNIe installation package). Then appears the window with a table and checked all columns, I press OK button. The result is "unable to open database file".
In the case of opening File -> Open Data File... I choose standard retention.txt file in Examples/Learning folder. The result is the same.
I would be very thankful for advice!
- retention.txt
- (7.4 KiB) Downloaded 1240 times
Since both ODBC import and text file load do not work on your machine, the likely explanation is the issue with SQLite, which powers GeNIe's data grid view.
Can you unzip the attached file and the open it in GeNIe?
- retention.zip
- (5.82 KiB) Downloaded 1403 times
SQLite is an embedded DB engine - this means that entire SQLite code is inside GeNIe's binaries.
The most probable explanation of your problems is an issue with Windows temporary directory - this is where temporary SQLite db file is created by GeNIe when you import ODBC data or open text file. To check what's the temp directory, type
at the command line. Try removing all files from that directory.
echo %TEMP%Temp directory was shown to be located at
C:\DOCUME~1\АЛЕСЯ\LOCALS~1\Temp
I have removed all files in it. Then I've tried to open data file, but an error was as in the previous cases. Maybe GeNIe stores temporary files at another directory? Or the problem occurs because of other reason?
Is it possible to import excel or access files into .dat or .gdat format and open them in GeNIe?
Re:
I maybe find the problemalesya wrote:Temp directory was shown to be located at
C:\DOCUME~1\ÐЛЕСЯ\LOCALS~1\Temp
In your local "C:\DOCUME~1\ÐЛЕСЯ\LOCALS~1\Temp"
the user name(ÐЛЕСЯ) may cause the error
try use english account
