Hello !
I have
1. made DBN with 3 time slice and then train dataset=11261 case (the training used the default settings of genie)
2. I have performed the following experiments (the target node called POS)
(temporal arc only on the node pos )
a. validate (2kfold)with class node pos at time t1 gives =79% accuracy
b.validate (2kfold)with class node pos at time t2 gives =81% accuracy
a. validate (2kfold)with class node pos at time t gives =76% accuracy
b.validate (2kfold)with class node pos at time t1 gives =84% accuracy
c.validate (2kfold)with class node pos at time t2 gives =84% accuracy
now im working on making the time slice =10 and see if the validation accuracy will be increased.
my questions:
>>I know that there exist so much factors affect the accuracy. and of course the dataset is one of them. in the second experiment I have count the frequency of all time slices for the pos node in the training set. and I found that pos at time t has the largest frequency although it has the smallest accuracy,why?
>>is my approach right? what should i do to have better performance?
>>I understood validation , but can we say that if validation get better accuracy then inference we have better accuracy?
>>when we make parameter learning should we set the target node?
DBN validation accuracy
Re: DBN validation accuracy
I'm sorry, but I can't understand this question. Please rephrase and/or post the training set.in the second experiment I have count the frequency of all time slices for the pos node in the training set. and I found that pos at time t has the largest frequency although it has the smallest accuracy,why?
>>why would the accuracy for a node at time t0 be lower than at time t=1?
I am somewhat confused by your experiment. I assume your data set is a time series since you have learned from it a DBN. In a time series, it is not surprising that you can determine the class better as time progresses. If it is a static data set, then I suspect you are dealing with over-fitting the data. These are my first impressions about what you are doing.
Hello Marek!
this is sample from my data set .
I don't understand
I would be grateful if you tell me what do you think? the validation accuracy are not clear for me. if you would like i can send you the details. and other experiments
I don't understand
.marek wrote:over-fitting the data
