The differences of the learning results
musicpxg
Post by musicpxg »
I found the learning results from the Smile were different from that using Genie. There are only three nodes, A, B, H. An arc from H to A and B respectively.
The CPT from H to A is
H h0 h1
a0 0.9215585808924782 0.1103564750941653
a1 0.0784414191075218 0.8896435249058347
It said: EM log-likelihood: 0.0
BUT, I tried to use the EM learning tool in Genie, the results are different:
H h0 h1
a0 0.9548764887866235 0.1536610658888118
a1 0.04512351121337653 0.8463389341111882
It said: Log(p) = -13.5
It has to note that the setEqSampleSize(0) was also used in Genie.
My code were as follows:
// Set up and config EM
EM em = new EM();
em.setEqSampleSize(0);
em.setRandomizeParameters(true);
em.setSeed(SEED_VALUE);
em.learn(data, network, data.matchNetwork(network));
The learning data are:
A B H
a0 b0 N/A
a0 b0 N/A
a0 b0 N/A
a0 b0 N/A
a0 b0 N/A
a0 b0 N/A
a1 b1 N/A
a1 b1 N/A
a1 b1 N/A
a1 b1 N/A
a0 b1 N/A
a1 b0 N/A
Thank you!
Have a nice weekends!
Regards,
Yang
Re: The differences of the learning results
The actual value of SEED_VALUE is missing from your post.
musicpxg
Post by musicpxg »
The SEED_VALUE is 0.
Yang
Zero seed causes the pseudorandom generator to initialize using the clock, effectively you're running a non-repeatable experiment.
musicpxg
Post by musicpxg »
Hi shooltz,
What the meaning of "setSeed"? Can I just discard the lines, as follow
SEED_VALUE = 0;
Thank you!
Have a nice Weekend!
Best wishes,
Yang
musicpxg wrote: What the meaning of "setSeed"? Can I just discard the lines, as follow
SEED_VALUE = 0;
The setSeed method initializes the seed for the pseudorandom generator used to randomize the parameters (if randomization is enabled). By fixing it at non-zero value you'll get the same initial values of the parameters before actual learning occurs.
If set to zero (which is the default), the generator will pick its initial state based on the system time. Effectively, each time you run the program you'll get different set of initial CPTs.
If you want to get repeatable results, you'll definitely need to fix the seed at some value. Also note that your current call - setSeed(0) - is a no-op, because zero is the default value.
