EM algorithm details
Ant_B
Post by Ant_B »
Hi Genie/Smile community,
I recently started to experiment with SMILE via JSmile. Following the documentation, I was able to get up and running - creating a network, reading in a simple data file that includes missing data, and performing EM on the dataset. The simple project is on my GitHub page (improvements/fixes very welcome):
https://github.com/amb-enthusiast/BayesianHack
I also repeated this exercise with SamIam's inflib.jar library and Mallet's GRMM library (part of the above GitHub project). When comparing results, I noticed a discrepancy: my by-hand calculations, GRMM and SamIam results all matched up with the tutorial notes. However, JSmile/SMILE gave different results. My hunch is that the differences are due to different initial estimated CPT values, but it may be something else.
I tried to look up details of the EM implementation, but couldn't find any details in this forum, or in the site documentation.
Having experimented with JSmile a little, I have a few questions about the SMILE EM implementation:
  • What is the default behaviour for JSmile/SMILE EM? In particular, what initial parameter estimate is used?
  • Is it possible to override these defaults, and supply initial parameters for the target BN to the EM algorithm?
  • Is it possible to set thresholds (on log-likelihood difference or max/target number of iterations) for EM execution?
I'd be grateful for any advice, information or guidance on these questions.
Thanks in advance,
Ant
Re: EM algorithm details
You can randomize, uniformize or use existing parameters as initial values. EM.setRandomizeParameters and EM.setUniformizeParameters control this behavior. Currently, randomize defaults to true and uniformize defaults to false (but I suggest calling setters anyway to express your intent explicitly).
See also EM.get/setEqSampleSize, which defaults to 1.
Is it possible to set thresholds (on log-likelihood difference or max/target number of iterations) for EM execution?[/list]
No, this is not controlled through the API.
