Question about discretize()
Tiranous
Post by Tiranous »
I am currently trying to use the discretize() method to discretize my data set. What do the numbers in the double[] represent? How do I convert a non-discretized node into a discretized node?
Re: Question about discretize()
These are the interval boundaries.
Node as in node in the network or rather a variable in the dataset?
Tiranous
Post by Tiranous »
That is what I was thinking, but the gui discretize boundries through the program doesn't match with the results of this.
I think variable in the dataset, here I am trying to convert file file1 (as a csv) into
file2 (as a csv).
file2.txt
the desired outcome done through discretize
(76.77 KiB) Downloaded 1719 times
file1.txt
The original file
(23.07 KiB) Downloaded 1412 times
Are you sure you're using the same discretization algorithm and bin count?
Tiranous
Post by Tiranous »
I figured out that the mismatch in data was due to the fact that when I used the GUI I highlighted all the variables and discretized them all at the same time. I assume this led the program to discretize them all together rather then separately as I thought it would work. Is there a way to discretize multiple variables together using the discretize method?
Tiranous wrote: Is there a way to discretize multiple variables together using the discretize method?
No. You'll need to invoke discretize() for each variable separately.
