Good Morning
I have defined the structure of my network. Some variables are continuous and I want to discretize their PDFs to make them work with discrete nodes. My problem is that I cannot find the GeNIe tool to do it. I would appreciate if someone could tell me how to find and use that tool in GeNIe.
Discretizing
Re: Discretizing
GeNIe supports discretization, however this will work only in the network containing only continuous nodes. If your models fits into this class, then you should define discretization intervals using node's properties and enable the AutoDiscretize option in Network|Algorithm. You can control the number of discretization samples and zero avoidance behavior through Discretization page in network properties.Some variables are continuous and I want to discretize their PDFs to make them work with discrete nodes
Re: Discretizing
Thanks for your answer; however I can't find the discretization page of the node.
If I have a file with distribution of the variable, can I discretize it?
Hector
Hector
Re: Discretizing
What are the names of pages you can see in node's property sheet?hector.reyesmoncayo wrote:Thanks for your answer; however I can't find the discretization page of the node.
Re: Discretizing
I found the discretization tab for the equation node.
I need to include decision and utility nodes in the model. Is there any way to do that if I have equation nodes?
Hector
Hector
Re: Discretizing
No, this is not supported at this point. The closest thing would be manually discretizing the equations (to obtain discrete BN) and adding influence diagram features. This is of course feasible only if your equations are unlikely to change.
