Inference in network
The default Lauritzen algorithm for updating the Bayesian network transforms the Bayesian network into a junction tree. If i call UpdateBeliefs multiple times to update the same Bayesian network structure with the same relations . Does UpdateBeliefs generate the junction tree for the Bayesian network once and saves it or is it generated each time i call UpdateBeliefs?
Re: Inference in network
Hi Ralph,
It's kept after it's created and is reused for later inferences.
Best,
Martijn
Best,
Martijn
Martijn's answer is incorrect. SMILE always re-creates the junction tree during the inference based on Lauritzen algorithm. When inference finishes the junction tree is discarded.ralph12 wrote: Does UpdateBeliefs generate the junction tree for the Bayesian network once and saves it or is it generated each time i call UpdateBeliefs?
Additionally, note that a forest of junction trees is created (not just one tree), because SMILE preprocesses the network using relevance algorithm, which may yield more than one separate network fragment.
