I’m trying to use the diagnosis network functions in GeNie / SMILE.
So I first mad a model in Genie with 4 Aberservation nodes, 1 Auxilary node and 4 Target nodes. Everything worked fine in the GeNIE Testing diagnosis Windows. After that, I tried to use SMILE for .NET with the same Network. I was able to read all kind of information about a nodes and also to instantiate an Observation, but I never get a FaultCount > 0 from the DiagNetwork atteched to my Network.
So I also builded the same Car example network as it is descriped in you doc. But I still have the same problem. And I tried your EngineFuelSystem.xdsl Example. Still FaultCount, UnperformedTestCount and the length of GetUnperformedObservations() are 0.
I use SMILE VC 9.0 RTM [12.5 MB] (March 25, 2008) and SMILE.NET Binaries [597 kB] (March 25, 2008).
I attached an image of my sample network.
Greetings,
Kai
- SampleNetwork.jpg (73.07 KiB) Viewed 15164 times
Re: diagnosis network functions in GeNie / SMILE
Can you post the actual network (not just the screenshot) here?
