libstdc++ and libc++ problem in osx 10.9
Hi
I am now using eclipse with MAC OS X 10.9. I am getting a problem with the libstdc++ and libc++.
If I used "-stdlib=libstdc++", I got
Building target: DBN
Invoking: MacOS X C++ Linker
g++ -L/Users/petercai/Documents/Libs/smile_macosx_gcc_4_2_1 -stdlib=libstdc++ -o "DBN" ./src/DBN.o ./src/DBNLearner.o -lsmile -lsmilearn
Undefined symbols for architecture x86_64:
"std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >::~basic_string()", referenced from:
DSL_datasetVarInfo::~DSL_datasetVarInfo() in DBNLearner.o
std::__1::__vector_base<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > >::~__vector_base() in DBNLearner.o
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make: *** [DBN] Error 1
If I used "-stdlib=libc++", I got
15:41:53 **** Incremental Build of configuration Debug for project DBN ****
make all
g++ -L/Users/petercai/Documents/Libs/smile_macosx_gcc_4_2_1 -stdlib=libc++ -o "DBN" ./src/DBN.o ./src/DBNLearner.o -lsmile -lsmilearn
"std::string::find(char, unsigned long) const", referenced from:
DSL_dataset::DoWriteFile(__sFILE*, DSL_datasetWriteParams const&, std::string&) const in libsmilearn.a(dataset.o)
XmlWriter::WriteContent(std::string const&, bool) in libsmile.a(xmlwriterimpl.o)
"std::string::size() const", referenced from:
DSL_dataset::PrepareStructure(DSL_network&) in libsmilearn.a(dataset.o)
std::basic_string<char, std::char_traits<char>, std::allocator<char> > std::operator+<char, std::char_traits<char>, std::allocator<char> >(char const*, std::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) in libsmile.a(xmlload.o)
XmlReader::OnCharacterData(char const*, int) in libsmile.a(xmlreaderimpl.o)
"std::string::c_str() const", referenced from:
DSL_dataset::MatchNetwork(DSL_network const&, std::vector<DSL_datasetMatch, std::allocator<DSL_datasetMatch> >&, std::string&) in libsmilearn.a(dataset.o)
DSL_dataset::WriteFile(std::string const&, DSL_datasetWriteParams const*, std::string*) const in libsmilearn.a(dataset.o)
DSL_datasetParser::ParseLine() in libsmilearn.a(dataset.o)
DSL_dataset::ReadFile(std::string const&, DSL_datasetParseParams const*, std::string*) in libsmilearn.a(dataset.o)
DSL_network::UpdateBeliefs() in libsmile.a(network.o)
It seems smilearn uses both libstdc++ and libc++ but they are not compatible (at least in OSX 10.9 now). Any solutions to this problem? Thanks.
Peter
make all
Peter
Re: libstdc++ and libc++ problem in osx 10.9
1. What's the output from gcc --version on your system?
2. Try building without -stdlib. g++ uses the standard C++ library by default.
petercai$ gcc --version
Configured with: --prefix=/Applications/Xcode.app/Contents/Developer/usr --with-gxx-include-dir=/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk/usr/include/c++/4.2.1
Apple LLVM version 5.0 (clang-500.2.79) (based on LLVM 3.3svn)
Target: x86_64-apple-darwin13.0.0
Thread model: posix
Building without stdlib:
g++ -L/Users/petercai/Documents/Libs/smile_macosx_gcc_4_2_1 -o "DBN" ./src/DBN.o ./src/DBNLearner.o -lsmile -lsmilearn
Thread model: posix
Could you perhaps tell me a bit more about DBN.o and DBNLearner.o?
How were they compiled?
These are from code that you've written?
Martijn
Martijn
DBN contains the smile tutorial code from smile webpage. DBNLearner is the following, which is basically just about definitions of DSL_network and DSL_dataset:
#ifndef DBNLEARNER_H_
#define DBNLEARNER_H_
#include <iostream>
#include <sstream>
#include <fstream>
#include "smile.h"
#include "smilearn.h"
using namespace std;
class DBNLearner {
public:
DBNLearner();
virtual ~DBNLearner();
DSL_network dynNet;
DSL_network tNet;
DSL_dataset dataset;
#endif /* DBNLEARNER_H_ */
#include "DBNLearner.h"
DBNLearner::DBNLearner() {
// TODO Auto-generated constructor stub
DBNLearner::~DBNLearner() {
// TODO Auto-generated destructor stub
#include <iostream>
#include <sstream>
#include <fstream>
#include "smile.h"
class DBNLearner {
public:
DBNLearner();
DSL_network dynNet;
DSL_network tNet;
Your issues may be related to discrepancy between the compiler used to build SMILE libraries and the one you're using. To diagnose the problem further, perform these step:
1. execute the "which g++" command. If g++ is a symlink, follow it and locate the actual binary invoked by the g++.
2. in the directory containing SMILE libraries and headers, execute the "file *.a" and "ls *.a" commands. Post the output.
3. copy the simple test program source into test.cpp, then execute the following command:
This should compile and link the program into a.out without any messages sent to console. If you see any messages, post them here.
g++ test.cpp -L<SMILE_DIR> -I<SMILE_DIR> -lsmile -lsmilearnCode: Select all
// test.cpp
#include "smile.h"
#include <stdio.h>
int main(void)
DSL_network net;
net.AddNode(DSL_CPT, "id");
int res = net.UpdateBeliefs();
printf("res=%d\n", res);
DSL_dataset ds;
ds.AddIntVar("v1");
printf("varcount=%d\n", ds.GetNumberOfVariables());
return res;
1)
petercai$ which g++
/usr/bin/g++
petercai$ ls -L /usr/bin/g++
/usr/bin/g++
2)
petercai$ file *.a
libsmile.a: Mach-O universal binary with 2 architectures
libsmile.a (for architecture x86_64): current ar archive random library
libsmile.a (for architecture i386): current ar archive random library
libsmilearn.a: Mach-O universal binary with 2 architectures
libsmilearn.a (for architecture x86_64): current ar archive random library
libsmilearn.a (for architecture i386): current ar archive random library
petercai$ ls *.a
libsmile.a libsmilearn.a
3)
petercai$ g++ test.cpp -L/Users/petercai/Documents/Libs/smile_macosx_gcc_4_2_1 -I/Users/petercai/Documents/Libs/smile_macosx_gcc_4_2_1 -lsmile -lsmilearn
test.cpp:8:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  DSL_network net;
test.cpp:8:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  DSL_network net;
test.cpp:9:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:9:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:10:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:10:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:11:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:11:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:12:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
 Â
test.cpp:12:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
 Â
test.cpp:13:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  DSL_dataset ds;
test.cpp:13:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  DSL_dataset ds;
test.cpp:14:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  ds.AddIntVar("v1");
test.cpp:14:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  ds.AddIntVar("v1");
test.cpp:15:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:15:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
test.cpp:17:1: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  return res;
test.cpp:17:4: warning: treating Unicode character as whitespace [-Wunicode-whitespace]
  return res;
18 warnings generated.
"DSL_dataset::AddIntVar(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> >, int)", referenced from:
_main in test-ZfJtJH.o
"std::string::empty() const", referenced from:
DSL_dataset::FindVariable(std::string const&) const in libsmilearn.a(dataset.o)
DSL_dataset::SetId(int, std::string const&) in libsmilearn.a(dataset.o)
DSL_dataset::AddVarHelper(std::string const&, bool, int, float) in libsmilearn.a(dataset.o)
DSL_dataset::Discretize(int, DSL_dataset::DiscretizeAlgorithm, int, std::string const&, std::vector<double, std::allocator<double> >&) in libsmilearn.a(dataset.o)
DSL_dbnImpl::Unroll(DSL_network&, std::vector<int, std::allocator<int> >&) const in libsmile.a(dbnimpl.o)
(anonymous namespace)::XmlNetLoader::GetAdderFunction() in libsmile.a(xmlload.o)
(anonymous namespace)::XmlNetLoader::NodeBinding::OnEndElement(IXmlReader*) in libsmile.a(xmlload.o)
"std::string::length() const", referenced from:
DSL_nameToIdentifier(std::string&, int) in libsmile.a(general.o)
(anonymous namespace)::XmlNetLoader::OnDoubleListItem(std::vector<double, std::allocator<double> >&) in libsmile.a(xmlload.o)
(anonymous namespace)::XmlNetLoader::EndBaseline(IXmlReader*) in libsmile.a(xmlload.o)
(anonymous namespace)::XmlNetLoader::EndPriorBelief(IXmlReader*) in libsmile.a(xmlload.o)
(anonymous namespace)::XmlNetLoader::OnIntListItem(std::vector<int, std::allocator<int> >&) in libsmile.a(xmlload.o)
DSL_expressionParser::Parse(std::string const&, std::string&, int&) in libsmile.a(exprparse.o)
"std::string::_M_iend() const", referenced from:
"std::string::compare(char const*) const", referenced from:
DSL_ConvertToHbnAndSolve(DSL_network&) in libsmile.a(equationsolver.o)
(anonymous namespace)::XmlNetLoader::ListItemParentTypes(IXmlReader*) in libsmile.a(xmlload.o)
(anonymous namespace)::XmlNetLoader::ListItemCost(IXmlReader*) in libsmile.a(xmlload.o)
(anonymous namespace)::XmlNetLoader::NodeBinding::OnStartElement(IXmlReader*) in libsmile.a(xmlload.o)
(anonymous namespace)::MauVarValidator::IsValid(std::string const&, std::string&) const in libsmile.a(defmau.o)
XmlBinding::FindAttribute(char const*) const in libsmile.a(xmlreaderimpl.o)
"std::string::compare(std::string const&) const", referenced from:
std::_Rb_tree<std::string, std::pair<std::string const, int>, std::_Select1st<std::pair<std::string const, int> >, std::less<std::string>, std::allocator<std::pair<std::string const, int> > >::_M_insert_unique(std::pair<std::string const, int> const&) in libsmilearn.a(dataset.o)
DSL_equationSolver::Evaluate(int, std::map<std::string, double, std::less<std::string>, std::allocator<std::pair<std::string const, double> > > const&, double&) in libsmile.a(equationsolver.o)
DSL_equationSolver::f(double*, double*, std::vector<int, std::allocator<int> > const&, std::map<std::string, double, std::less<std::string>, std::allocator<std::pair<std::string const, double> > > const&) in libsmile.a(equationsolver.o)
DSL_equationSolver::Exact() in libsmile.a(equationsolver.o)
"std::string::capacity() const", referenced from:
"std::string::operator[](unsigned long) const", referenced from:
XmlReader::GetUnescapedContent(std::string&) in libsmile.a(xmlreaderimpl.o)
"std::allocator<char>::allocator(std::allocator<char> const&)", referenced from:
DSL_datasetParser::ReadLine() in libsmilearn.a(dataset.o)
std::vector<char, std::allocator<char> >::_M_fill_insert(__gnu_cxx::__normal_iterator<char*, std::vector<char, std::allocator<char> > >, unsigned long, char const&) in libsmilearn.a(dataset.o)
int DoDatasetDiscretize<int>(DSL_dataset&, int, std::vector<int, std::allocator<int> > const&, int, int, std::vector<double, std::allocator<double> >&, std::vector<int, std::allocator<int> >&, std::vector<char, std::allocator<char> >&) in libsmilearn.a(dataset.o)
int DoDatasetDiscretize<float>(DSL_dataset&, int, std::vector<float, std::allocator<float> > const&, int, int, std::vector<double, std::allocator<double> >&, std::vector<int, std::allocator<int> >&, std::vector<char, std::allocator<char> >&) in libsmilearn.a(dataset.o)
"std::allocator<char>::allocator()", referenced from:
MapIndex(std::map<std::string, int, std::less<std::string>, std::allocator<std::pair<std::string const, int> > >&, char const*) in libsmilearn.a(dataset.o)
DSL_datasetParser::GetColumns() in libsmilearn.a(dataset.o)
"std::allocator<char>::~allocator()", referenced from:
"std::string::end()", referenced from:
(anonymous namespace)::fromUTF8(std::string&) in libsmile.a(xmlreaderimpl.o)
"std::string::swap(std::string&)", referenced from:
DSL_operator::WriteOperand(DSL_expression const*, std::string&, bool) const in libsmile.a(expression.o)
"std::string::begin()", referenced from:
"std::string::append(char const*)", referenced from:
DSL_neticaSpeaker::WriteTokenStringPair(char const*, char const*) in libsmile.a(netica.o)
(anonymous namespace)::XmlNetLoader::EvidenceStart(IXmlReader*) in libsmile.a(xmlload.o)
DSL_equationSCC::DSL_equationSCC(int, DSL_network*) in libsmile.a(defequationscc.o)
DSL_equationSCC::ComposeDefaultEquation(std::string&) in libsmile.a(defequationscc.o)
DSL_hybridSampleNet::MarkSampleReviseNodes(int const&) in libsmile.a(samplenethybrid.o)
"std::string::append(char const*, unsigned long)", referenced from:
"std::string::append(std::string const&)", referenced from:
"std::string::replace(__gnu_cxx::__normal_iterator<char*, std::string>, __gnu_cxx::__normal_iterator<char*, std::string>, char const*, char const*)", referenced from:
"std::string::reserve(unsigned long)", referenced from:
(anonymous namespace)::XmlNetworkSaver::SaveIntArray(char const*, DSL_intArray*) in libsmile.a(xmlsave.o)
(anonymous namespace)::GetUnescapedContent(IXmlReader*, std::string&) in libsmile.a(xmlgenieload.o)
"std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(char const*, std::allocator<char> const&)", referenced from:
DSL_datasetWriteParams::DSL_datasetWriteParams() in libsmilearn.a(dataset.o)
"std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::string const&)", referenced from:
DSL_datasetParser::XlateMapped(int, std::map<std::string, int, std::less<std::string>, std::allocator<std::pair<std::string const, int> > > const&) in libsmilearn.a(dataset.o)
std::string* std::__uninitialized_copy_aux<__gnu_cxx::__normal_iterator<std::string const*, std::vector<std::string, std::allocator<std::string> > >, std::string*>(__gnu_cxx::__normal_iterator<std::string const*, std::vector<std::string, std::allocator<std::string> > >, __gnu_cxx::__normal_iterator<std::string const*, std::vector<std::string, std::allocator<std::string> > >, std::string*, std::__false_type) in libsmilearn.a(dataset.o)
__gnu_cxx::new_allocator<DSL_datasetVarInfo>::construct(DSL_datasetVarInfo*, DSL_datasetVarInfo const&) in libsmilearn.a(dataset.o)
std::string* std::__uninitialized_copy_aux<std::string*, std::string*>(std::string*, std::string*, std::string*, std::__false_type) in libsmilearn.a(dataset.o)
"std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string()", referenced from:
"std::basic_string<char, std::char_traits<char>, std::allocator<char> >::~basic_string()", referenced from:
"std::string::operator=(char const*)", referenced from:
"std::string::operator=(std::string const&)", referenced from:
std::vector<std::string, std::allocator<std::string> >::operator=(std::vector<std::string, std::allocator<std::string> > const&) in libsmilearn.a(dataset.o)
"std::string::operator=(char)", referenced from:
DSL_expression::Write(std::string&) const in libsmile.a(expression.o)
"std::string::operator[](unsigned long)", referenced from:
"std::string::operator+=(char const*)", referenced from:
CalcNewCpt(DSL_network&, int, DSL_intArray const&, DSL_Dmatrix&, DSL_progress*, int, int) in libsmile.a(network.o)
DSL_appendInt(std::string&, int) in libsmile.a(general.o)
DSL_dbnImpl::CreateUnrolledId(std::string&, DSL_network&, int, int) const in libsmile.a(dbnimpl.o)
"std::string::operator+=(std::string const&)", referenced from:
DSL_neticaSpeaker::ReadNodeField(int) in libsmile.a(netica.o)
(anonymous namespace)::XmlNetLoader::SetDeterministic(DSL_nodeDefinition*) in libsmile.a(xmlload.o)
"std::string::operator+=(char)", referenced from:
(anonymous namespace)::XmlNetLoader::StdStopParse(char const*, std::string const&) in libsmile.a(xmlload.o)
"std::ios_base::Init::Init()", referenced from:
__GLOBAL__I__Z11creat_s_netP12DSL_rNetwork in libsmile.a(sampling.o)
__GLOBAL__I__ZN18HBNSamplingAdapterC2ER11DSL_network in libsmile.a(hbnsamplingadapter.o)
__GLOBAL__I__ZN19DSL_hybridSampleNetC2EP18HBNSamplingAdapter in libsmile.a(samplenethybrid.o)
__GLOBAL__I__ZN20DSL_hybridSampleNodeC2EP19DSL_hybridSampleNeti in libsmile.a(samplenodehybrid.o)
"std::ios_base::Init::~Init()", referenced from:
___tcf_0 in libsmile.a(sampling.o)
___tcf_0 in libsmile.a(hbnsamplingadapter.o)
___tcf_0 in libsmile.a(samplenethybrid.o)
___tcf_0 in libsmile.a(samplenodehybrid.o)
"std::_Rb_tree_decrement(std::_Rb_tree_node_base const*)", referenced from:
DSL_dbnImpl::GetPrevFlatChild(std::_Rb_tree_const_iterator<std::pair<std::pair<int, int> const, int> >) const in libsmile.a(dbnimpl.o)
DSL_dbnImpl::EnsureChildExists(int, int) in libsmile.a(dbnimpl.o)
DSL_dbnImpl::GetStartParentPos(std::_Rb_tree_const_iterator<std::pair<std::pair<int, int> const, int> >) const in libsmile.a(dbnimpl.o)
DSL_dbnImpl::GetMaxOrder(int) const in libsmile.a(dbnimpl.o)
"std::_Rb_tree_decrement(std::_Rb_tree_node_base*)", referenced from:
std::_Rb_tree<int, int, std::_Identity<int>, std::less<int>, std::allocator<int> >::_M_insert_unique(int const&) in libsmilearn.a(dataset.o)
std::_Rb_tree<int, std::pair<int const, int>, std::_Select1st<std::pair<int const, int> >, std::less<int>, std::allocator<std::pair<int const, int> > >::_M_insert_unique(std::pair<int const, int> const&) in libsmilearn.a(dataset.o)
std::_Rb_tree<int, std::pair<int const, int>, std::_Select1st<std::pair<int const, int> >, std::less<int>, std::allocator<std::pair<int const, int> > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<int const, int> >, std::pair<int const, int> const&) in libsmilearn.a(dataset.o)
std::_Rb_tree<std::string, std::pair<std::string const, double>, std::_Select1st<std::pair<std::string const, double> >, std::less<std::string>, std::allocator<std::pair<std::string const, double> > >::_M_insert_unique(std::pair<std::string const, double> const&) in libsmile.a(equationsolver.o)
std::_Rb_tree<std::pair<int, int>, std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > >, std::_Select1st<std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > > >, std::less<std::pair<int, int> >, std::allocator<std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > > > >::_M_insert_unique(std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > > const&) in libsmile.a(dbnimpl.o)
std::_Rb_tree<std::pair<int, int>, std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > >, std::_Select1st<std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > > >, std::less<std::pair<int, int> >, std::allocator<std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > > > >::_M_insert_unique(std::_Rb_tree_iterator<std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > > >, std::pair<std::pair<int, int> const, std::vector<double, std::allocator<double> > > const&) in libsmile.a(dbnimpl.o)
"std::_Rb_tree_increment(std::_Rb_tree_node_base const*)", referenced from:
DSL_equationSolver::EvaluateSCC(int, std::map<std::string, double, std::less<std::string>, std::allocator<std::pair<std::string const, double> > > const&, std::map<std::string, double, std::less<std::string>, std::allocator<std::pair<std::string const, double> > >&) in libsmile.a(equationsolver.o)
DSL_dbnImpl::OnDeleteOutcome(int, int) in libsmile.a(dbnimpl.o)
DSL_dbnImpl::OnInsertOutcome(int, int) in libsmile.a(dbnimpl.o)
DSL_dbnImpl::GetUnrolledParents(int, int, std::vector<std::pair<int, int>, std::allocator<std::pair<int, int> > >&, int&) const in libsmile.a(dbnimpl.o)
"std::_Rb_tree_increment(std::_Rb_tree_node_base*)", referenced from:
DSL_dbnImpl::SetSliceCount(int) in libsmile.a(dbnimpl.o)
DSL_dbnImpl::OnChangeType(int) in libsmile.a(dbnimpl.o)
void (anonymous namespace)::EraseNodeHelper<std::map<std::pair<int, int>, int, std::less<std::pair<int, int> >, std::allocator<std::pair<std::pair<int, int> const, int> > > >(int, std::map<std::pair<int, int>, int, std::less<std::pair<int, int> >, std::allocator<std::pair<std::pair<int, int> const, int> > >&, std::map<int, int, std::less<int>, std::allocator<std::pair<int const, int> > >&, DSL_network&) in libsmile.a(dbnimpl.o)
DSL_dbnImpl::DeleteUnusedNodes(int) in libsmile.a(dbnimpl.o)
"std::__throw_length_error(char const*)", referenced from:
std::vector<std::string, std::allocator<std::string> >::_M_insert_aux(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string const&) in libsmilearn.a(dataset.o)
std::vector<int, std::allocator<int> >::_M_insert_aux(__gnu_cxx::__normal_iterator<int*, std::vector<int, std::allocator<int> > >, int const&) in libsmilearn.a(dataset.o)
std::vector<float, std::allocator<float> >::_M_insert_aux(__gnu_cxx::__normal_iterator<float*, std::vector<float, std::allocator<float> > >, float const&) in libsmilearn.a(dataset.o)
std::vector<std::string, std::allocator<std::string> >::_M_fill_insert(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, unsigned long, std::string const&) in libsmilearn.a(dataset.o)
std::vector<DSL_datasetMatch, std::allocator<DSL_datasetMatch> >::reserve(unsigned long) in libsmilearn.a(dataset.o)
std::vector<DSL_datasetMatch, std::allocator<DSL_datasetMatch> >::_M_insert_aux(__gnu_cxx::__normal_iterator<DSL_datasetMatch*, std::vector<DSL_datasetMatch, std::allocator<DSL_datasetMatch> > >, DSL_datasetMatch const&) in libsmilearn.a(dataset.o)
std::vector<char const*, std::allocator<char const*> >::_M_insert_aux(__gnu_cxx::__normal_iterator<char const**, std::vector<char const*, std::allocator<char const*> > >, char const* const&) in libsmilearn.a(dataset.o)
"std::_Rb_tree_rebalance_for_erase(std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)", referenced from:
DSL_dbnImpl::ClearEvidence(int, int) in libsmile.a(dbnimpl.o)
std::_Rb_tree<int, std::pair<int const, int>, std::_Select1st<std::pair<int const, int> >, std::less<int>, std::allocator<std::pair<int const, int> > >::erase(std::_Rb_tree_iterator<std::pair<int const, int> >, std::_Rb_tree_iterator<std::pair<int const, int> >) in libsmile.a(dbnimpl.o)
std::_Rb_tree<std::pair<int, int>, std::pair<std::pair<int, int> const, int>, std::_Select1st<std::pair<std::pair<int, int> const, int> >, std::less<std::pair<int, int> >, std::allocator<std::pair<std::pair<int, int> const, int> > >::erase(std::_Rb_tree_iterator<std::pair<std::pair<int, int> const, int> >, std::_Rb_tree_iterator<std::pair<std::pair<int, int> const, int> >) in libsmile.a(dbnimpl.o)
std::_Rb_tree<std::pair<int, int>, std::pair<int, int>, std::_Identity<std::pair<int, int> >, std::less<std::pair<int, int> >, std::allocator<std::pair<int, int> > >::erase(std::_Rb_tree_const_iterator<std::pair<int, int> >, std::_Rb_tree_const_iterator<std::pair<int, int> >) in libsmile.a(dbnimpl.o)
DSL_equationElement::SetInvEquation(std::string const&, std::string const&) in libsmile.a(helement.o)
"std::_Rb_tree_insert_and_rebalance(bool, std::_Rb_tree_node_base*, std::_Rb_tree_node_base*, std::_Rb_tree_node_base&)", referenced from:
petercai$ which g++
/usr/bin/g++
/usr/bin/g++
2)
petercai$ file *.a
petercai$ ls *.a
3)
  DSL_network net;
  DSL_network net;
 Â
 Â
  DSL_dataset ds;
  DSL_dataset ds;
  ds.AddIntVar("v1");
  ds.AddIntVar("v1");
  return res;
  return res;
What does ls -l /usr/bin/llvm* show?
petercai$ ls -l /usr/bin/llvm*
lrwxr-xr-x 1 root wheel 7 4 Nov 16:41 /usr/bin/llvm-g++ -> clang++
lrwxr-xr-x 1 root wheel 5 4 Nov 16:41 /usr/bin/llvm-gcc -> clang
You'll probably need to find out how to install previous version of gcc. As your gcc --version reported, you're now at LLVM 5.0, while SMILE was built with LLVM 4.2.petcai wrote:petercai$ ls -l /usr/bin/llvm*
If you have XCode installed already, check if it came with OSX 10.8 SDK. If this is the case, your system may have previous compiler version somewhere.
Thanks, Shooltz. I am currently working with the windows version. I will check this out later.
