Are Smile jars OS independent or dependent?
ATCadman
Post by ATCadman »
We are building an application using jsmile which we run on Windows (using smile.jar and jsmile.dll), Linux (using smile.jar and libjsmile.so) and OS X (using smile.jar and libjsmile.jnilib).
Do we need to use a different jar for each operating system? Initial tests showed that the same jar worked on all different operating systems, but because they are different sizes we wanted to check whether this is the case.
many thanks,
Andrew
Re: Are Smile jars OS independent or dependent?
The desktop platforms use the same jar. The jar for Android is slightly different due to lack of java.awt.Color and java.awt.Rectangle.
ATCadman
Post by ATCadman »
Many thanks for that.
