GENIE software ouput
sa265
Post by sa265 »
Hi ,
I wish to know if it is possible to save the model as an executable file. So that it could be run from an external software command line.
Also if it possible to output the the results in the form of an excel sheet.
Re: GENIE software ouput
sa265 wrote: wish to know if it is possible to save the model as an executable file. So that it could be run from an external software command line.
No, that's not possible.
You can use the Validate option to run the data through the model and obtain a dataset as a .csv file - Excel should be able to load such file.
