I searched the forum in order to find some explanations about sensitivity analysis in GeNIe. However everything what I found did not answer for my questions.
The sensitivity analysis is based on "Sensitivity analysis in descrete Bayesian networks" by Castillo et al if I'm not mistaken. However, I did not understend what actually is implemented. What are the steps of analysis in GeNie?
I will appreciate any ideas or links
gosia
Re: sensitivity analysis
The implementation is based on "Making Sensitivity Analysis Computationally Efficient" by Kjaerulff and van der Gaag.Mastif wrote:The sensitivity analysis is based on "Sensitivity analysis in descrete Bayesian networks" by Castillo et al if I'm not mistaken.
See the last post in this thread:What are the steps of analysis in GeNie?
http://genie.sis.pitt.edu/forum/viewtop ... vity#p3291
from http://genie.sis.pitt.edu/forum/viewtop ... vity#p3291You can view the actual sensitivity values in node's CPT table. With sensitivity enabled the background color of CPT cells is based on their respective sensitivity. For actual numeric value, hover the mouse cursor over the cell to show the tooltip.
In tooltip we have three value max, min and average. I'm a little bit confuse how to interpret this numbers. Are they upper and lower bounds? but what in this case "Avg" means?
Am I correct, that the n-way sensitivity to parameters analysis is implemented? if so how the min, max and average are calculated.
and one more...
Does a sensitivity to findings analysis is implemented in GeNIe?
thanks
gosia
The tooltip you're referring is based on the sensitivity coefficients calculated for each entry in node's CPT. As they have different values we show min, max and the average (Avg). If you open the node's definition page when sensitivity mode is on, you'll be able to see the coefficients for each CPT entry by hovering the mouse cursor over the grid cells.In tooltip we have three value max, min and average. I'm a little bit confuse how to interpret this numbers. Are they upper and lower bounds? but what in this case "Avg" means?
No, the implementation in SMILE/GeNIe performs the analysis of selected (possibly all) outputs wrt to all parameters.The implementation is based on "Making Sensitivity Analysis Computationally Efficient" by Kjaerulff and van der Gaag
I'm not sure what you mean by findings analysis.Does a sensitivity to findings analysis is implemented in GeNIe?
thanks
gosia[/quote]
ooooo. .. I see
thanks, you have helped me a lot
