Information about network properties
ind
Post by ind »
I haven't found any information about network property values in summary tab. There are object count, states, parameters / independent. How does Genie calculate values for "parameters" and "independent"?
Re: Information about network properties
ind wrote:I haven't found any information about network property values in summary tab. There are object count, states, parameters / independent. How does Genie calculate values for "parameters" and "independent"?
The parameter count is the total size of CPTs and noisy tables in the network (the unit is table element, to get total size in bytes multiply by 8).
Independent parameter count is obtained by ignoring the last row in the CPTs (because each column total must be 1.0).
