.NET assembly won't link against .NET 4.0
BioPhysEngr
Post by BioPhysEngr »
Hello!
I've been using SMILE for a few things recently (e.g. http://goo.gl/jYwbZ) under C# and found it to be a fantastic library. However, I've noticed that I can only link assemblies that target the .NET 3.5 framework; if I try to link a .NET 4.0 program to SMILE, I get error messages. Compilation succeeds, but I get thrown a runtime error, using a very simple test program (see below).
I've tried (unsuccessfully) to re-compile the .NET library to target the 4.0 assembly on my own.
Any chance the maintainers would be willing to re-build assemblies those to target the .NET 4.0 or even 4.5 framework? Perhaps we could leave the current ones, too, for backward compatibility?
Thanks for your help!
Test program:
using System;
using Smile;
namespace TestSmile40
	class Program
		public static void Main(string[] args)
			Smile.Network net = new Network();
Re: .NET assembly won't link against .NET 4.0
BioPhysEngr wrote:I've tried (unsuccessfully) to re-compile the .NET library to target the 4.0 assembly on my own.
What problems did you encounter?
