DBN Learning
Tidustseng
DBN Learning
Post by Tidustseng »
I was wondering the format in the example of training data.
Why is A A_0 A_1 rather than A A_1 A_2?
Appreciate your answer.
Sincerely.
Tidus.
Re: DBN Learning
Tidustseng wrote:Why is A A_0 A_1 rather than A A_1 A_2?
The DBN column naming scheme is only used by automatic matching algorithm in GeNIe's 'Time Series' window, and it is actually "A A_1 A_2". This particular implementation was chosen to minimize the development cost.
In your SMILE-based or jSMILE base program you'll have to perform network/data matching yourself, so any naming convention will work.
Tidustseng
Re: DBN Learning
Hi, shooltz,
Thank you very much. I tried two settings, then got two different results as the attachments.
I was wandering which is correct? Thanks again.
Sincerely.
Tidus
res_tut_6_AA1A2.xdsl
(3.92 KiB) Downloaded 1221 times
res_tut_6_AA0A1.xdsl
(4.4 KiB) Downloaded 1348 times
Re: DBN Learning
Tidustseng wrote:I tried two settings, then got two different results as the attachments.
You don't provide enough context to answer this question. Did you run EM in GeNIe or in your own program?
