hello
i have problem when i learning structure with Bayesian Search
i have data 25 column and 400 line = 25*400
i get erreur vector<T> too long
help me please
BayesianSearch problem
Re: BayesianSearch problem
Could you show part of code causing that error?
azzedine_fcb
data.readFile("new 2.txt");
BayesianSearch b= new BayesianSearch();
b.setMaxParents(24);
b.setRandSeed(25);
bkk.addForcedArc("age","class");
bkk.addForcedArc("pc","class");
bkk.addForcedArc("pcc","class");
bkk.addForcedArc("rbcc","class");
bkk.addForcedArc("wbcc","class");
bkk.addForbiddenArc(1, 3);
bkk.addForbiddenArc(1, 9);
bkk.addForbiddenArc(24, 1);
b.setBkKnowledge(bkk);
System.out.println(" learning");//is begin learning but never end learning
net= b.learn(data);//problem in this
System.out.println("end learning");
b.setRandSeed(25);
I forgot to ask about JVM error stack - it could be helpful.
Also, did you matched BKK with DataSet?
(code should be executed after bkk initialization)
Last thing - did forced and forbidden arcs aren't excluding each other?
bkk.matchData(data);Last thing - did forced and forbidden arcs aren't excluding each other?
azzedine_fcb
yes I matched BKK with DataSet
and no jvm error stack he terminated without error
when i use that code with dataset 9*100 he is run successfully
but with 24*400 he is terminated with msg vector<T> too long for 80%
and run successfully for 20%
I tried to reproduce that error with random data, but it was ineffective. I suspect the end of RAM memory, but 24x400 DataSet is not that big.
If your data is not confidential, archive your project and data into ZIP or RAR and send as attachment to support@bayesfusion.com
We will do our best to help you.
