issue with setting evidence
burnsmc
Post by burnsmc »
I have a stationary network with a node 'Day' that has 365 states (one for each day of the year). Any day I select past 200 automatically sets a control value to a different state. If I set Day observed to any day between 1 and 200 it works as intended and all other values update accordingly. Why is this happening and how do I get it to stop? I have made the same network on a temporal plate and it gives me no issues past 200.
Thanks,
Meghan
Safe2Fly_static_noLearning.xdsl
(426.09 KiB) Downloaded 1647 times
Re: issue with setting evidence
The problem is with GeNIe's menu command range reserved for the evidence states. As you just discovered, it's just 200 entries. Any outcomes above 200 fall out of the range and GeNIe can't handle the command properly. We'll increase the reserved range in the next release. In the meanwhile, the following workaround is feasible:
1. open the Case Manager pane from the View menu
2. uncheck the Show Only Evidence Nodes option in Case Manager's toolbar (the button has the grounding symbol icon)
3. you'll get the grid with columns for all nodes in your network
4. click on the Add New Case button on the tooolbar
5. select the appropriate node states in the menu
6. click the Apply Case button on the toolbar - this will use the evidence defined in the case and set it in the network.
Meghan,
Thanks for finding this bug -- we will fix it in the next release. I just wanted to comment here that having 365 states is not a usual modeling practice. I don't know your problem and can't advise without knowing it but I feel that you are asking for problems by having a node with so many states. Please note that any child of this node will have at least 365 columns in the CPT. Two of such nodes being parents of a node will result in at least 100K columns. You will exhaust your memory very quickly. Please rethink this.
Good luck!
burnsmc
Post by burnsmc »
Thanks everyone! The workaround was successful. I realize that this is not the most efficient way to solve the problem, but that was actually the point of doing it this way as an example for my thesis.
