I would like to report a seeming problem with GeNIe 2.2. The following sequence of operations
results in a program crash:
1. Create three equation nodes: Node1, Node2 and Node3
2. Connect Node1 -> Node3, and Node2->Node3
3. Retain the default definitions of all nodes, wherein Node1=0,Node2=0 and Node3=Node1+Node2
4. Update network
5. View Node3 as Bar Chart.
This results in a crash. The specific values of Node1 and Node2 do not matter, any two constants would do. Other functions in the definition of Node3 will also lead to a crash. No similar crash happens if Node1 or Node2 are defined as, e.g., distributions.
Kind regards.
Sergiy Kondratyuk.
Simple Equation-Based Network Crashes on Conversion of Node to Bar Chart
s.kondratyuk
Re: Simple Equation-Based Network Crashes on Conversion of Node to Bar Chart
I can't reproduce the problem on my machine using the steps from your message. Are you using GeNIe 2.2.2028.x?
s.kondratyuk
Thank you for your reply. I am using Version 2.2.2028.2 (64-bit). Please note that this is a licensed copy.
Thanks again.
Thanks again.
s.kondratyuk
Another qualification: after the steps described originally, please save the network, then open it again and update. This will produce a crash, on my version at least. Thanks.
Ok, we can reproduce the problem after the reload. The fix should be available soon.
The bug is fixed in GeNIe 2.2.2106.x, which is online now.
s.kondratyuk
Thank you very much!
