Hi everyone,
I am working on an equation-based BN, and I'd like to export some of the values obtained from equation based nodes into a chance node Network, using this values as propabilities of a state in a chance node. I need the equation based because values are obtained from beta distributions, at the same time a chance node permits me to make a sensitivity analysis of data obtained.
I know I cannot use equation and chance nodes in the same network, but is there any way to connect at least values obtained from an eq node to a chance node?
Thank you so much.
Read data from equation to chance nodes
Re: Read data from equation to chance nodes
This is possible - define the discretization intervals for your equation nodes (in node properties), then use Network|Continuous Models|Discretize.I am working on an equation-based BN, and I'd like to export some of the values obtained from equation based nodes into a chance node Networ
This is true; however, we're going to enable the hybrid models (networks with both continuous and discrete nodes) in GeNIe 2.2. The new version will be released in late April.I know I cannot use equation and chance nodes in the same network
