Does that mean that you can compile and link your program?There is no problem.
smile for Vs2010
Re: smile for Vs2010
No, I mean the ones you say are normal, but the problem is still there.
Rebuild the project and post the complete output from the build pane after the /MTd -> /MDd change.
Set the default is / MDd, do not need to modify.
- 新建文本文档.txt
- (122.12 KiB) Downloaded 1220 times
The output from build (for the debug configuration) contains references to the non-debug SMILE library, like this one:
This should not happen. The SMILE library selection is done by smile.h, which uses #pragma directive with appropriate filename based on your build configuration. You don't need to manually add SMILE libraries in Linker|Input|Additional Dependencies - remove these and rebuild the project.
D:\Visual Studio 2010\smile_vc10_x86\smile.lib:
It's work! Thank you very very much!
