I'm working with SMILE libraries (on OSX 10.10) trying to open a .xdsl model file created using GENIE on a Windows VM. I got stuck with an error in the probability format since GENIE exports probabilities with the '.' and the library function seems to expected them with the ',' character. Is it something that I can control in the library somehow? The actual solution consists in changing them manually, that goes in the wrong direction without saying.
Thanks.
Ale
File Open Error on Probablities Format
Re: File Open Error on Probablities Format
Try adding the following line just before DSL_network::ReadFile call:
If this solves the problem, you can ensure that your locale settings are preserved by using this class (this is actually internal part of jSMILE):
setlocale(LC_NUMERIC, "C");Code: Select all
example usage:
// block to ensure c'tor and d'tor run
DefLocaleCtx lctx;
res = net.ReadFile(filename);
class DefLocaleCtx
public:
DefLocaleCtx();
~DefLocaleCtx();
private:
std::string defLocale;
DefLocaleCtx::DefLocaleCtx()
char *loc = setlocale(LC_NUMERIC, NULL);
if (NULL != loc)
defLocale = loc;
DefLocaleCtx::~DefLocaleCtx()
if (!defLocale.empty())
setlocale(LC_NUMERIC, defLocale.c_str());
xavier7179
Yes, it works just fine!
Thanks for solving my issue.
