Runtime Error of create structure with PC
Razi
Post by Razi »
i am new with Genie. I have .csv data with 2265 case. Each time that i try to learn structure with PC as i click on "Only create structure" on "Pattern Editor" windows it comes Runtime Error "Microsoft Visual C++ Runtime Library"
Any one has idea what should i do?
thanks in advance
Re: Runtime Error of create structure with PC
Razi wrote:as i click on "Only create structure" on "Pattern Editor" windows it comes Runtime Error "Microsoft Visual C++ Runtime Library"
That's the bug in GeNIe. Can you share your .csv file so we can reproduce the problem?
Razi
Post by Razi »
I can't upload .csv file hear . how should i share the file else?
Razi wrote:I can't upload .csv file hear . how should i share the file else?
Try renaming the file to .txt. Alternatively, zip the file.
Razi
Post by Razi »
here you are :)
test.zip
(20.6 KiB) Downloaded 1402 times
MarcinK
Post by MarcinK »
Indeed, there is a crash after attempt to get the structure after applying PC algorithm.
I would like to point out that the data contain variables with many possible states (up to 11). What does it mean? When there are a lot of in-arcs in a one of nodes, then this node will have huge conditional probability table (CPT)
example:
node with 10 states and 10 in-arcs from 10 variables with 8 states will produce conditional table with 10 multiplied by 8 power to 10 what is roughly 10000000000 parameters in CPT.
I guess this is the reason why there is a possible memory problem not covered by the software.
Did You try extremely lower significance level for PC algorithm?
(PS. I have to change the break line character to read the data into GeNIe)
--Marcin
Razi,
You should limit the number of connections in your learned graph. There are two ways of doing this: (1) change the significance level to very small, e.g., 0.0000000001, (2) reduce the Max Adjacency Size to a smaller number (3-4?) so that the graph is not so dense. Marcin has pointed out correctly that you have created a graph that GeNIe cannot represent in the available memory of your computer.
I hope this helps.
A correction to my prior post. Setting a limit on the Max Adjacency will not help (I made a mistake here). However, please enter some prior knowledge, such as temporal precedence of variables. It seems that you are reasonably aware of temporal precedence based on what I am reading in the names of the variables. This will prevent some of the arcs from occurring.
Good luck!
Razi
Post by Razi »
Thanks for your answers. Actually as the model didn't work i tried with different significance leveles but the problem is it works first for 0.0000000000000000000000000000000000000000000000000003 which is really too small is :roll: but never mind if there is not another way to learn this structure with PC.
Actually, we believe that there is and we will post an update at some point. Stay tuned :-).
