Continuous variables & gaussian states
Hello all,
I have a couple of questions that might be a bit simple, but that I don't understand very well.
1. How can I use continuous variables in my DBN in Genie?
2. And second, is there any way of having a probability density function, let's say a Gaussian, defining the conditional probability between two or more nodes?
Thank you very much for your help.
Kind regards,
Oscar
Kind regards,
Oscar
Re: Continuous variables & gaussian states
I'm afraid we have not ported continuous variables to dynamic models yet
. There are no theoretical reasons against it, so if you make a good case, we will push on it.
As far as your second question goes, I think it should be possible. If you tell me what precisely you want, I'll try to construct a model that does it.
I think it s interesting question this one.
There is. If you tell me what exactly you want, I will be glad to help
. Cheers -- Marek
For exemple, it's the distribution of the two parameters that describe a normal distribution.
Try constructing a model consisting of three continuous variables (green node with a wave), call them mu, sigma, and x. Then you can use the values of the variables called mu and sigma to parametrize the distribution of x (essentially, define x=Normal(mu,sigma)). I hope this helps.
Marek,
Your post shows my lack of the knowledge of Genie:
I don't know how to " define x=Normal(mu,sigma)".
Cheers.
Didier
Cheers.
Didier
Open the properties of node x, select the "Definition" page and type the equation "x=Normal(mu, sigma)". Next, press the OK button.Gardiola wrote:I don't know how to " define x=Normal(mu,sigma)".
Shooltz,
OK thanks for this.
I was just working on the learning of the structure for the the data first.
I totally ignored the decision dimensions so far.
I will start to work on this aspect from now: it looks very powerfull to make any decisions !!!
Cheers.
Didier
OK thanks for this.
Cheers.
Didier
How can we combine plain chance nodes with equation nodes?
Currently you can't do that. This feature is high on the to-do list.Bayesian wrote:How can we combine plain chance nodes with equation nodes?
