SMILE procedures
tloy1966
SMILE procedures
Post by tloy1966 »
Greetings!!!
I am newbie to Computer Science(CS) who interest in Bayesian Network(BN) :?
when i study in statistic field , they can handle model with statistic method which called Structural Equation Modeling(SEM)
and in CS field , we can model a problem with BN , then make a decision
like i said before , then i got a lots of problem with Using SMILE....
Q1. i had read SMILE Tutorials,the procedures are (i)create a model with node and arc, (ii)give the probability, (iii)Performing Inference with BN
if i had made my model with background knowledge, and i have data,
Can i perform Inference with SMILE by follow procedure ????(i) create my model, (ii)read data from .csv file , so i don't need to fill the conditional distribution with many node (iii) Performing Inference with BN
Or i have to perform Inference by Genie?
Re: SMILE procedures
If the .csv file contains the learning data, you can run EM algorithm (parameter learning) as step 2 in your procedure.
tloy1966
Post by tloy1966 »
Thanks a lot!
I will try this :D
Is my steps of perform Bayesian Network right????????????
In my related work. There are about one thousand nodes and many links....
I had a network which made by background knowledge. And how can i use Genie or Smile to perform Bayesian Network.
I have read some documents in this website.
And one my idea of using Genie by following steps
(i) File → Open data file → Data → Learn new network → Background Knowledge → Build my network
but like i said i have one thousand nodes and links...so i think about using Smile by following steps
(i) Create nodes (ii) Create links between nodes (iii) run EM algorithm (iv) performing Inference with BN
Is that steps right???
Thanks again :D
Yes, this is the correct approach when you have the network structure already.
tloy1966
Post by tloy1966 »
thanks !!!!
tloy1966
Post by tloy1966 »
Thanks again :D
Here is my simple test using VS2010 to create a Bayesian network
Q1 : I can run this without problem! But i don't know is that right?
Another question is about why run em algorithm when i have no miss value???
Sorry for lack domain knowledge... :oops:
Q2 : Has any website or paper can explain the reason!!?
Thanks!!!
#include "StdAfx.h"
#include <iostream>
#include "smile.h"
#include "smilearn.h"
using namespace std;
void testBN()
//read data
DSL_dataset d;
DSL_datasetParseParams params;
params.columnIdsPresent = false;
d.ReadFile("ds_tut_5.txt", &params);
//read network
DSL_network result;
result.ReadFile("net_tut_5.xdsl");
//match data with network
vector<DSL_datasetMatch> matches;
string err;
d.MatchNetwork(result, matches, err);
//run em algorithm
DSL_em em;
em.Learn(d, result, matches);
result.WriteFile("test.xdsl");
int main()
testBN();
