Load evidence to model
Warbird
Post by Warbird »
Hi
I am wondering if there is any way to preload evidence to the network?
I am using a BN in GeNIe as a trubleshooting model and have a lot of nodes which evidence is needed to be set from observations which I will have.
Best wishes
Re: Load evidence to model
Warbird wrote:Hi
Try to open Case Manager pane from the View menu. Cases are stored in .xdsl file.
Warbird
Post by Warbird »
Ok, with the case manager I can set target nodes. But how do I assign values to them? Is there any smart way to assign values to these nodes from a data file?
Best wishes
The target nodes are not directly related to evidence.
To create new case, set the evidence in the main graphical view, then click 'Add case' button in the Case Manager's toolbar.
Alternatively, you can disable 'Show only evidence nodes' option in the Case Manager's toolbar, invoke 'Add case' and set the required evidence using the dropdown lists in appropriate node columns. Of course you can mix two approaches, the cases are editable.
