Hello:
I am using SmileX with Excel. How could I use "Clustering" algorithm with SmileX?
SmileX manual says we can use Lauritzen, Henrion, Pearl, LSampling, SelfImportance, HeuristicImportance and Backsampling. All of them for BN. But not Clusterin.
Thanks very much
SmileX and Clustering algorithm
Re: SmileX and Clustering algorithm
Lauritzen is clustering.jga wrote:I am using SmileX with Excel. How could I use "Clustering" algorithm with SmileX?
Thanks, very much.
Then How can I explain the difference betwen the results with SmileX and Genie. I could compare the results obtained with Genie and SmileX with the same BN in two cases. With the first BN (very simple, with only 4 nodes) the results were very similar (insignificant difference), but with another BN with 30 nodes aprox. there are differences:
With GENIE: 0,764 - 0,253 - 0,979
With SmileX: 0,686 - 0,287 - 0,945
Is that normal?
Thaks
Is that normal?
Thaks
Can't reproduce that with the following script (run from the command line with 'cscript test.vbs'):jga wrote:The first case. And the probabilities correspond to T1, T2 and T3.
dim net
set net = CreateObject("SmileX.SmileXCtrl.1")
net.ReadFile "rb.xdsl"
net.SetEvidence "A", "Hombre"
net.SetEvidence "B", "E15_34"
net.SetEvidence "C", "Positivo"
net.SetEvidence "F", "Negativo"
net.SetEvidence "G", "Negativo"
net.SetEvidence "H", "Positivo"
net.SetEvidence "L", "Vida_cama_sillon"
net.SetEvidence "N", "Negativo"
net.SetEvidence "R", "Dificultas_Ronquidos"
net.SetEvidence "S", "Negativo"
net.SetEvidence "V", "Extension_en_respuesta_al_dolor"
net.SetEvidence "X", "Al_dolor"
dim res
res = net.UpdateBeliefs("Lauritzen")
Wscript.Echo "UpdateBeliefs status code:", res
dim b
b = net.GetBeliefs("T1")
Wscript.Echo "T1:", b(0), b(1)
b = net.GetBeliefs("T2")
Wscript.Echo "T2:", b(0), b(1)
b = net.GetBeliefs("T3")
Wscript.Echo "T3:", b(0), b(1)
T1: 0.235561961436078 0.764438038563923
T2: 0.021294296604007 0.978705703395993
T3: 0.746880495503305 0.253119504496695
