Learn Parameters
Lindgren
Learn Parameters
Post by Lindgren »
When you have opened a Data File you can under the Data menu choose Learn Parameters.
I'm wondering what learning algorithm, if any, is used for this?
Thank you in advance.
Janne
Re: Learn Parameters
The algorithm is called EM (expectation maximization).
Lindgren
Post by Lindgren »
Thank you for the help! :)
Lindgren
Post by Lindgren »
I have another question that relates to this so I'll try asking it here.
I been doing an online survey and it's getting close to completion and I'm eager to process the data. I can get the data from the survey as either a *.csv or *.xls file. The excel file doesn't work at all while the CSV-file loads.
But.
It never finishes. Instead I'm told "Trailing separator found in header line"
What can I do to fix this? Can I change something in the CSV file? Or maybe do something with the excel file?
Thanks in advance.
Check the first line in the file - the message you're getting suggests that the last character in that line is comma.
Lindgren
Post by Lindgren »
Yes, that helped. Thanks! :)
