Saving evidence
gasparz
Saving evidence
Post by gasparz »
I am using Smile in a project that generates BN automatically from data in a database.
As the size of the BN is large 300-1000 nodes and because for some nodes I set evidence values automatically I would like to save the evidence I set to the xsdl file. This can be useful so that I can open the network in Genie, maybe set some more evidence or just play with the network.
Can I do a thing like this, or is there some work around?
Thank,
Gasparz
Re: Saving evidence
gasparz wrote:Can I do a thing like this, or is there some work around?
Yes, you can add cases to the network (DSL_network::AddCase method, DSL_simpleCase class). In GeNIe, use View|Case Manager option.
HoloDoc
Post by HoloDoc »
What if I'm using JSmile, is there a possibility to add cases as well?
HoloDoc wrote:What if I'm using JSmile, is there a possibility to add cases as well?
No, this functionality is not exposed through jSMILE at this point. However, we provide full source code for jSMILE, so it should be quite easy to extend the library in order to provide access to the cases.
