node definition
sara
node definition
Post by sara »
concerning the conditional probability I do not know how I will display the value of the probability when i did net.getNodeDefinition(nodeHandle)
the result was
how can i get the value of the probabilities?
Re: node definition
net.getNodeDefinition(nodeHandle) in your post suggests you're using jSMILE and Java. To obtain the calculated probabilities, you should call Network.getNodeValue.
Please refer to SMILE Wrappers Manual, the Tutorials section and Tutorial 2:
https://support.bayesfusion.com/docs/Wr ... _java.html
You can find links to all our manuals in HTML and PDF formats at:
