When I import pysmile, I get the following error:
undefined symbol: PyUnicodeUCS4_FromStringAndSize
From my understanding, this is due to a mismatch between the compiled pysmile.so file and my python build in the number of bits used to store unicode characters.  Is there a build of pysmile that uses a UCS2 unicode definition? Or is there another way around this issue?
Thank you,
Matt
						Issue importing pysmile: "undefined symbol: PyUnicodeUCS4_FromStringAndSize"
Re: Issue importing pysmile: "undefined symbol: PyUnicodeUCS4_FromStringAndSize"
I need some informations first, if you want me to help you.
1. Which OS you have?
2. Which Python you are using? (python -V)
3. Your Python Unicode config (print sys.maxunicode)
Best regards,
Piotr
Best regards,
Piotr
Thank you for your help.  My specs are as follows:
1. Scientific Linux
2. Python 2.7.9
3. The output of "print sys.maxunicode": 65535
						1. Scientific Linux
2. Python 2.7.9
As you said - it's mismatch between unicode used to Python compilation. Unfortunately, we don't have build dedicated for Python builded with UCS2. At this moment, only way to use PySmile is to have Python compiled with UCS4.
