Equation nodes based network and sensitivity analysis
jakub
Post by jakub »
Hi All,
I have developed a simple 40-node network where each node is an equation node.
Then I wish to run a sensitivity analysis, but I can not.
GeNie crashes each time the sensitivity button is activated.
I am not sure, if it is feasible, from the conceptual view point, to run a sensitivity analysis on continuous nodes?
Or only discreet nodes are eligible nodes?
If the analysis is not supported by continuous nodes, then is there any other way to find the most affecting variables?
I will appreciate any help on this topic.
Regards,
Jakub
