DeleteNode Behavior
yuriy
DeleteNode Behavior
Post by yuriy »
I'm using jSMILE so this will be in Java notation but I imagine that this is language-independent.
Suppose I have a network (of discrete CPDs) where A --> B. What happens to the CPD of B when A is deleted by calling network.deleteNode( A's handle )? It doesn't seem to be documented...
Particularly, I'm trying to get a subnetwork out of a larger network by deleting nodes and I'm wondering if the probabilities will end up consistent.
Thanks.
Re: DeleteNode Behavior
The B's CPT will shrink and the remaining entries are values associated with A's 0th state. This also happens when you only delete the A-->B arc (and A remains in the network).
The probabilities managed by SMILE are always consistent.
yuriy
Post by yuriy »
Thanks, that answers my question.
shooltz wrote:The probabilities managed by SMILE are always consistent.
By "consistent" you mean summing to 1?
I was being too vague in my last post: what I meant by "consistent" is whether P(B=1) in the resulting network will be the same as P(B=1) in the original.
Based on your response it will not.
yuriy wrote:By "consistent" you mean summing to 1?
Yes, that's correct. When network structure changes (including arc add/delete and parent outcome add/delete), the CPTs are modified by copying existing columns or by removing the columns.
