I learned the parameters of my Bayes-net using the EM-algorithm. I have no a priori knowledge about the parameters. Is it better to start with a uniform distribution or to runthe algorithm n-times using the randomize-initial-parameters-option and choose the one with the highest log(p)-value?
If I use the randomize-initial-parameters-option: is it also better to start with the uniform distribution since for some combinations exist no training data.
For combinations where no training data exist the EM-algorithm even with randomizing of initial-parameters seems nothing to change. So it is also with using randomizing important for the result to start with plausible start parameters. Is starting with a uniform distribution here the best?
By the way im surprised that even with randomizing parameters the same result is achieved for the combinations where training data exists. I used around 2000 data records and exactly the same parameters (until to last digit after the dot) were the result.
samoth
initial parameters
Re: initial parameters
To answer your questions, can you tell me how much of the data is missing and are there variables that have no data at all?
Hallo,
my training data sets are all complete.
samoht
samoht
Then these settings don't really matter. If there is no data available for a certain parameters in a CPT, then these won't be updated and will keep their original uniform or randomized values.
