Is there an option to copy all the Items from C# Dataset to Smile Dataset ?
Another question if i can read specific table from access Db (Like GeNIe allows).
Boris
Using DataSet
Re: Using DataSet
No, there's no .Net-specific functionality in Smile.Learning.DataSet. You'll need to iterate over the contents of your ADO.NET (or whatever data access technology you're using) and add columns/records to your Smile.Learning.DataSet object.borisrabin wrote:Is there an option to copy all the Items from C# Dataset to Smile Dataset ?
borisrabin
Re: Using DataSet
shooltz wrote:No, there's no .Net-specific functionality in Smile.Learning.DataSet. You'll need to iterate over the contents of your ADO.NET (or whatever data access technology you're using) and add columns/records to your Smile.Learning.DataSet object.borisrabin wrote:Is there an option to copy all the Items from C# Dataset to Smile Dataset ?
My only option is insert cell by cell or i can insert full row?
Re: Using DataSet
You'll need to use DataSet.AddEmptyRecord for each row, then fill it with DataSet.SetInt/SetFloat calls. Don't forget to set up the columns first with DataSet.AddIntVariable/AddFloatVariable.borisrabin wrote:My only option is insert cell by cell or i can insert full row?
