UserProperties bug
apopescu
UserProperties bug
Post by apopescu »
I have created a network with a single node in Genie and
set one user property to the node.
Smile API is returning an empty array for UserProperties of that node.
Have anyone faced this problem before?
Adrian
Re: UserProperties bug
I can't reproduce the problem. Make sure you're accessing the user properties of correct node. If problem persists, post the network and code here.
apopescu
Post by apopescu »
Here is the model I'm using.
The Smile code is listed below:
String id="TESTCHANCE";
UserProperty[] properties1 = network.getNodeUserProperties(id);
if (properties1 != null && properties1.length > 0) {
for (UserProperty property : properties1) {
System.out.println(id + "," + property.name + "," + property.value);
System.out.println("-------------------");
The property wasn't listed.
Network2.xdsl
Genie model
(721 Bytes) Downloaded 1690 times
The snippet outputs the following line after loading the model you've attached in the previous post:
TESTCHANCE,TEST,test
apopescu
Post by apopescu »
We are building the model manually by reading the nodes out of the XDSL file and using addArc and different setters from Network.
Maybe the way we are constructing the model has flaws.
Is there a way in Smile API to pass the xdsl file to a method or constructor and get a Network or DiagNetwork as a result?
apopescu wrote:Is there a way in Smile API to pass the xdsl file to a method or constructor and get a Network or DiagNetwork as a result?
I believe you're using jSMILE - in this case, you should call Network.readFile and pass filename as the single argument in function call.
apopescu
Post by apopescu »
I've tried to use Network.readFile method and it worked fine.
The problem was in our code.
Thanks for your reply.
