network too complex to be updated
I have a BN with 38 nodes, all being noisy-adders. Many nodes have 4 to 5 parents and 4 states. To perform sensitivity analysis I have to convert the BN into cpt nodes, but then upon running the BN it shows "Error(42): UpdateBeliefs failed - network structure is too complex". Is such a BN really too complex? The sensitivity analysis still runs but should I trust the results if the BN cannot be updated properly?
Re: network too complex to be updated
It runs when I have set the evidence for all the final parent nodes. Don't know why. The network is definitely not complex.
The network can be densely connected and triangulation can fail to produce a reasonably sized jointree, even with 38 nodes.
Can you share your model, so we can investigate? You can send me a forum private message if you don't want the network to be publicly available.
Hi Shooltz
Thanks for the advice. It's working as long as I set evidence to the last row of parental nodes - that's totally fine with us as we need to do that anyway.
Regards
Charles
Regards
Charles
