error message regarding /lib64/libm.so.6
BayesFusionUser123
Post by BayesFusionUser123 »
I am using the 2.4.0 version of pysmile.
Name: pysmile Version: 2.4.0
Summary: BayesFusion's SMILE wrapper
Home-page: [https://bayesfusion.com/](https://bayesfusion.com/)
Author: BayesFusion LLC Author-email: support@bayesfusion.com
In my local machine, my Linux is cutting edge, and there is no issue. If I use this newest version on the server, it reports errors like
File ".../tutorials/python/tutorial1.py", line 1, in <module>
    import pysmile
ImportError: /lib64/libm.so.6: version `GLIBC_2.29' not found (required by .../anaconda3/envs/smile/lib/python3.11/site-packages/pysmile.so)
I cannot upgrade the Linux system of the server in the university, as it is a cluster.
Is there any way to fix this issue without upgrading the Linux system on the server? Thanks.
Re: error message regarding /lib64/libm.so.6
Which Linux distro runs on your cluster?
BayesFusionUser123
Hi, here is the Linux information for the cluster, using command
cat /etc/os-release
NAME="Rocky Linux"
VERSION="8.10 (Green Obsidian)"
ID="rocky"
ID_LIKE="rhel centos fedora"
VERSION_ID="8.10"
PLATFORM_ID="platform:el8"
PRETTY_NAME="Rocky Linux 8.10 (Green Obsidian)"
ANSI_COLOR="0;32"
LOGO="fedora-logo-icon"
CPE_NAME="cpe:/o:rocky:rocky:8:GA"
HOME_URL="https://rockylinux.org/"
BUG_REPORT_URL="https://bugs.rockylinux.org/"
SUPPORT_END="2029-05-31"
ROCKY_SUPPORT_PRODUCT="Rocky-Linux-8"
ROCKY_SUPPORT_PRODUCT_VERSION="8.10"
REDHAT_SUPPORT_PRODUCT="Rocky Linux"
REDHAT_SUPPORT_PRODUCT_VERSION="8.10"
I have sent you a download link using private forum message.
BayesFusionUser123
Thank you shooltz[BayesFusion].
I have installed and tested, and it looks good.
Just to confirm, after I installed the whl file using the command `pip install [whl file]`, the .so file automatically appears in my Python virtual environment package folder.
So, I do not need to do anything with the .so file provided in the Google Drive you shared with me, right?
Thanks.
Correct, the .so file from the .tar.gz archive is for the scenario where you do not use pip.
